Those brave warriors who have already completed the Fremennik Trials have a challenging new quest to get their teeth into.
The Fremennik Isles quest introduces a new area larger than Falador to enjoy and explore, featuring two new villages, new mines to plunder, armour to make, trees to chop, yaks to skin and a huge smelly rabble of trolls to confront.
The islands of Jatizso & Neitiznot were founded by two quarreling Fremennik brothers who left the land of their father to prove themselves. Instead of finding two isolated lands to rule without worrying about each other, they unwittingly set up as neighbours, and their feud continues to this day. However, a new foe has threatened their silly sibling squabbling. Trolls, more trolls and yet more trolls - led by the imposing Ice Troll King - lurk nearby. Each village is only a few bridges away from troll-ish destruction.
Normally, you’d expect two strong and noble Fremennik clans to unite together and defeat the yak-eating, bone-crunching trolls, but the years of petty name-calling and abuse have meant that the brothers fear each other more than the trolls that threaten to destroy them. Are you prepared to step into this quagmire of resentment to deal with the real threat?
Fremennik warriors brave and wise enough to accept the challenge will need to be skilled with their hands, using knife and axe as well as sword. You’ll be killing yaks, building bridges, collecting taxes, fashioning smelly armour, donning disguises to spy on important meetings and dodging rocks before taking on the might of the Ice Troll King and his horde.
Barbarian Assault
Down in the murky Barbarian Assault caverns, change is in the air. The barbarians have installed a new dispenser for Collectors to use. It converts eggs from one type to another: green eggs to red eggs, red and blue eggs to green eggs. Only Collectors of levels 2 or above may make use of this feature. The dispenser is not perfect, and eggs have a high chance of being destroyed. Higher-level Collectors have a far better chance of the eggs surviving the transformation process; this is to give more of a reason for levelling up the Collector role.
The barbarians have also increased the supplies available to Attackers. Their dispenser now gives runes and arrows in multiples of 50 rather than 15, and its stock now includes death runes. Although this would normally make Ancient Magicks available in the area, the Barbarians strongly prefer players not to use any such spells.
The egg launcher's interface now lists how many eggs of each type it contains.
The cavern used for Wave 10 has been slightly modified to stop penance runners getting stuck.
In other news...
Servants in player-owned houses are now subject to increased security measures. In particular, they will now require you to enter your Bank PIN when you ask them to withdraw items from the bank, unless you've already entered it since you logged in.
Ava's Attractor and Accumulator will no longer work on non-members' worlds.
Rings of recoil and rings of forging have a handy new feature. If you right-click on them via the Worn Items interface and choose the "Operate" option, they will tell you how many more charges they've got.
Alle tapferen Krieger, die schon die
Fremennik Trials absolviert haben, können sich jetzt an einer neuen Quest die Zähne ausbeißen:
Die
Fremennik Isles Quest ermöglicht es Spielern, eine neue Region - größer als
Falador - zu erforschen, mit zwei neuen Dörfern, neuen Mining-Plätzen, Rüstungen, Bäumen, Yaks, und der Herausforderung, es mit einem großen Clan übel stinkender Trolle aufzunehmen.
Die Inseln
Jatizso und Neitiznot wurden begründet von zwei zerstrittenen Fremennik-Brüdern, die, um sich selbst zu beweisen, das Land ihrer Väter verließen. Statt zwei von einander getrennte Landstücke zu besiedeln, die sich von ihnen beherrschen ließen, ohne sich über einander zu ärgern, ließen sie sich unbeabsichtigt nebeneinander nieder, und so dauert ihre Fehde bis zum heutigen Tag an. Wie auch immer: ein neuer Widersacher kam in ihren albernen Bruderstreit: Trolle, immer mehr Trolle und noch mehr Trolle - angeführt vom imposanten Eis-Trollkönig - lauern in der Nähe. Jedes der beiden Dörfer ist nur eine Hand voll Brücken entfernt von der Zerstörung durch die Trolle!
In der Regel würde man erwarten, dass sich zwei starke und edle Fremennik Clans verbünden und die Yak-fressenden, knochenzermalmenden Trolle vernichten würden, aber die Jahre kleiner Sticheleien und Beleidigungen führten dazu, dass sich die Brüder nun vor einander mehr fürchteten als vor den Trollen, die sie bedrohten. Bist Du bereit, in diesen Sumpf voll Ärger zu steigen, um die wahre Herausforderung anzunehmen?
Fremennik-Krieger, die tapfer und weise genug sind, die Herausforderung anzunehmen, müssen geschickt mit ihren Händen sein, wenn sie das Messer, die Axt und auch das Schwert nutzen. Du musst Yaks töten, Brücken bauen, Steuern eintreiben, muffige Rüstungen gestalten, maskiert wichtige Treffen ausspionieren und Felsbrocken ausweichen, bevor Du die Macht über den Troll- Eiskönig und seine Horde übernehmen kannst!
Barbarian Assault
In den düsteren Höhlen von
Barbarian Assault liegen Veränderungen in der Luft. Die Barbaren haben einen neuen Verteiler errichtet, der von Sammlern genutzt werden kann. Er wandelt Eier in eine andere Farbe um: grün zu rot und rot & blau zu grün. Jedoch können nur Collectors mit einem Level von 2 oder höher diese Möglichkeit nutzen. Der Verteiler arbeitet nicht ganz zuverlässig, es besteht also die Wahrscheinlichkeit, daß die Eier dabei zerstört werden können. Collectors mit einem höheren Level haben bessere Chancen, die Eier umzuwandeln. Ein Grund mehr, die Rolle eines Collectors zu trainieren.
Die Barbaren haben außerdem das Angebot für Attacker aufgestockt. Der Verteiler gibt nun mehr als dreimal soviele Runen und Pfeile aus wie üblich. Death Runes sind von jetzt an ebenso vorhanden. Obwohl damit theoretisch
Ancient Magic möglich wäre, möchten die Barbaren diese Zaubersprüche nicht sehen.
Das Bedienfeld vom Egg Launcher zeigt nun an, wieviele Eier und welche Typen enthalten sind.
Die Höhle, in der die zehnte Angriffswelle stattfindet, wurde so verändert, daß Penance Runner nicht mehr steckenbleiben können.
Weitere Neuigkeiten...
Die
Diener in deinem Haus wurden nun mit den Sicherheitsmaßnahmen vertraut gemacht. Sie verlangen von dir die Eingabe deines
Bank PINs, wenn sie für dich Gegenstände aus der Bank holen sollen. Dies entfällt, wenn du deinen PIN seit dem letzten Login schon eingegeben hast.
Der
Attractor und Accumulator von Ava funktionieren nun nicht mehr in F2P Welten.
Rings of Recoil und Rings of Forging haben eine neue Eigenschaft. Mit einem Rechtsclick und der Auswahl "Operate" verraten sie dir, wieviele Aufladungen noch übrig sind.
zum Originalartikel auf Runescape.com
