Ava's lab work has triumphed once more as her chicken knowledge expands. Users of the
rewards from the
Animal Magnetism quest will now notice that their devices now aid automatically in the recovery of fired missiles. This functionality operates for all arrow types commonly in use. Effects cannot, however, be guaranteed where obstacles lie between the wearer of the device and the fired arrows. All existing devices have had this enhancement fitted automatically; just equip your backpack, and your chicken will be ready to serve.
(In other words, the chicken will now retrieve most of the ammunition that would have otherwise dropped on the ground while you're ranging, but it can't do this if there's something in the way.)
It should also be noted that stocks of convenient scavenging materials in RuneScape are rather depleted. As a result, the arrow generation function of these devices has slowed considerably. Users should not be alarmed by this change which is due to natural effects beyond Ava's control.
In other news...
The
games necklace has been updated to teleport players to the Barbarian Outpost as well as the
Burthorpe Games Room.
Convenient right-click options have been added to the
Magic Carpets and Gnome Gliders.
A bug has been fixed that was allowing players to cast
Lunar spells on friends in non-multiway-combat areas of the Wilderness.
Now that the Christmas festivities have passed, the Gublinch cave has been sealed, the Karamjan snow has melted and Shantay Claws has sailed away to a distant land to learn more sea shanties; apparently the normal Karamjan climate doesn't suit werewolves. Players who'd rescued the childernapped childerkins (don't ask) and claimed their reward hat and tree will still have those items. Replacements may be obtained at any time from Diango in
Draynor Village.
Ava hat bei ihrer Arbeit einen weiteren Durchbruch erzielt, während sich ihre Kenntnisse über Hühner weiter verbessern. Diejenigen, die die
Belohnung vom
Animal Magnetism Quest verwenden, werden feststellen, dass ihre Geräte jetzt automatisch beim Wiederfinden von abgefeuerten Geschossen helfen. Diese Funktionalität wirkt bei allen gängigen Pfeiltypen. Die Wirkung kann aber nicht garantiert werden, falls Hindernisse zwischen dir und den verschossenen Pfeilen stehen. Alle existierenden Geräte wurden um diese Verbesserung automatisch erweitert; zieh einfach Deinen Rucksack an, und das Huhn nimmt dir die Arbeit ab.
(Mit anderen Worten, das Gerät sammelt jetzt automatisch die meisten Pfeile auf, die du verschiesst. Dies funktioniert allerdings nur, wenn kein Hindernis im Weg ist.)
Es sollte beachtet werden, dass die Bestände an geeignetem Material in RuneScape ziemlich erschöpft sind. Als Folge ist die Pfeilproduktion dieser Geräte erheblich verlangsamt worden. Man sollte durch diese Veränderung nicht beunruhigt sein, da sie auf natürliche Effekte zurückzuführen sind, auf welche Ava keinen Einfluss hat.
Weitere Neuigkeiten ...
Das
Games Necklace wurde aktualisiert und teleportiert die Spieler jetzt nicht nur zum
Burthorpe Games Room, sondern auch zum Barbarian Outpost.
Den
Magic Carpets und Gnome Gliders wurden bequeme rechts-click Optionen hinzugefügt.
Ein Fehler, welcher es ermöglichte,
Lunar Zaubersprüche auf Freunde in nicht-multicombat Gegenden der Wildniss anzuwenden, wurde beseitigt.
Jetzt wo die Weihnachtsfestlichkeiten vorbei sind, wurden die Gublinch Höhlen verschlossen, der Schnee auf Karamja ist geschmolzen und Shantay Claws ist zu fernen Ländern weitergesegelt; anscheinend mögen Werwölfe das normale Karamja Klima nicht. Spieler, die die gekidnappten Kinder gerettet und den Hut und Baum zur Belohnung abgeholt haben, werden die Belohnung behalten. Ersatz dafür gibt es jederzeit bei Diango in
Draynor Village.
Link zum Originalthema auf Runescape.com
