Wirklich Top Beni dass du's nochmal probierst, ich hoffe dass ich in nächster Zeit auch genügend Zeit habe mich selbst daran zu beteiligen =)
Was mir nur eben an Pegalne's Post auffällt:
Ich persönlich finde die Slayer-Informationen gerade für z.B. Feuerriesen unglaublich nützlich. Damit ihr versteht was ich meine zitiere ich hier jetzt mal den Teil aus Zarfot's Guide, ich hoffe das stört ihn nich...
GFC zu seinem Guide ist 98-99-703-58532304
O. Fire Giants
Amount assigned: Duradel, 130-199; Sumona, 120-185
Hitpoints: 111
Locations: Smokey Well, Chaos Tunnels, Brimhaven Dungeon, Wilderness Dungeon, Waterfall Dungeon
Fire Giants occasionally drop a rune scimitar or fire battlestaff, as well as fire runes and herbs.
Approximate charm drop percentages-
Gold: 63%
Green: 10%
Crimson: 7%
Blue: 1%
Summoning to Slayer xp: 0.70 to 0.93
Although you could kill Fire Giants pretty fast by meleeing in the Chaos Tunnels, especially with a combat familiar, the absolute fastest way to kill them is to melee and cannon them in the Waterfall. Slightly slower, but worth mentioning because of the extra range xp, is range and cannon in Waterfall.
However, if you have a very good titan (Iron or Steel), you may find it faster in the long run to use the Chaos Tunnels even though the Waterfall is still fastest under ideal conditions since you won't have to deal with world switching at the Waterfall. Personally I would even kill them in the Chaos Tunnels even with only have a Geyser Titan if it's a peak time. A good location is to go in the entrance in level 11 wilderness or so directly noth of Edgeville, go east to get to a large room with Fire Giants, and use the 3 spawns in the southwest part of the room.
But continuing with the Waterfall method: When you get a Fire Giants task, bank, teleport to Barbarian Outpost using your Games necklace, take the raft to the south, and enter the Waterfall.
1. Range method
For the range method, use the door safespot in the eastern room with Fire Giants and set up your cannon 5 squares north and 1 square west of where you are standing.
The equipment is just the typical range equipment.
Suggested inventory:
Holy wrench
A teleport
Cannon and Cannonballs
2 crystal bows
Glarial's amulet
Rope
Games necklace
1-3 range pots
3-7 prayer pots
A few food items; Wines work since you are ranging
Pray either Hawk Eye or Eagle Eye.
With maxed stats, the Hawk Eye method gives about 285 kills (31.6k slayer xp) per hour, and the Eagle Eye method gives about 300 kills (33k slayer xp) per hour.
2. Melee method
This is the method that I suggest using here, unless you need range xp, since it's very fast, plus a bit cheaper.
Suggested inventory for melee method-
A teleport
Holy wrench
Dragon dagger(p++) or Saradomin Godsword
Rope
Glarial's amulet
Games necklace
2 super sets
4-8 prayer pots
Food in extra space
(Familiar: Beast of Burden or Healer, if needed)
The best cannon spot for melee and cannon that I've found is to set up the cannon 2 squares southwest of the square 1 east of the table. With that spot there are many ways to get double shots; for example, by standing 2 squares southwest of the cannon, your cannon will double shoot the Fire Giants that approach you from the north/northwest and from the east/southeast.
Pray either Superhuman Strength or Piety. With maxed stats, a full world, and empty room, the Superhuman Strength method gives about 300 kills (33k slayer xp) per hour and the Piety method gives about 320 kills (35k slayer xp) per hour.
For both the range and melee methods, you'd probably want to switch worlds if there is more than one person at the Fire Giants there. It's an automatic switch if someone else has a cannon. During peak times you may be better off meleeing them in the Chaos Tunnels even if you don't have a good combat familiar.
Note that it is also possible to just not switch worlds even if several people are there. Most people will leave within 10 minutes once you set up your cannon and begin killing. However, you will get a lot of nasty comments, so I don't really like doing that.
Note: It is possible to Dharok Fire Giants in the Smokey Well, since the smoke cannot kill you and you can stay at 1 hp. However, it is actually not faster than meleeing normally, let alone using a cannon as well.
Ja, das ist lang und ausführlich. Aber genau DAS ist ein Guide wie ich ihn mir wünsche. Man erfährt ALLES wichtige, und nicht nur den Basic-Kram den sowieso jeder halbwegs gute Spieler kennt.
Z.B. die Info wo man die Cannon am besten aufstellt ist für mich etwas extrem wesentliches gewesen. Ich liebe Zarfots Guide, und fände es einfach nur genial wenn etwas vergleichbar gutes bei der deutschen RSC entstehen würde.
Also was ich sagen will: Ich halte es für 100% sinnvoll, egal für welche Monster =)
Wie gesagt, ich denke ich werd mich auch beteiligen wenns möglich ist.
